1989 Ford Bronco how to replace my fuel pump
TAUGHT
Engine Mechanical problem
1989 Ford Bronco V8 Four Wheel Drive Automatic
need a class on fuel pump replacement. hope you can help me.
Nov 26, 2009 at 4:09 AM
BIGJIM79
  • 239 POSTS
Is it fuel injected? I know this stupid question but some are still carbed in this year! Sheesh I know.
Dec 1, 2009 at 12:40 PM
TAUGHT
Yes, it is fuel injected. If this thing is in the fuel tank, how much of a bear will this be?
Dec 4, 2009 at 3:42 AM
BIGJIM79
  • 239 POSTS
Its like grizzly. If your going to tackle this by yourself, I would recommended borrowing a transmission jack. It wil be a lot easier on yah. The tank drop is not that bad but once you get it lose, watch out not to stretch the wiring harness. and you will need to get a set of gas and ac line tools as these will be used to remove the gas lines. They,re about 13.00. Once out it will have a locking ring that will be rotated CCW. The install is reverse of removal of course. I would change fuel filter while i had it down such as the fuel pump sock. I hope this helps.
Dec 5, 2009 at 2:49 AM
TAUGHT
Thanks a bunch for the info, every bit helps. Yessir the plan is to tackle this grizzly!
Dec 5, 2009 at 4:45 AM
