fuel pump location
150,000 MILES • V8 • 4WD • AUTOMATIC
HAZZMATT
Where is the fuel pump located on a 1989 bronco and what will I need to do to access it?
Jul 5, 2010 at 11:46 AM
RICHZOMBIE
  • 173 POSTS
Two electric pumps are used on fuel injected models; a low pressure boost pump mounted in the fuel tank and a high pressure pump mounted on the vehicle frame.
The low pressure pump is used to provide pressurized fuel to the inlet of the high pressure pump and helps prevent noise and heating problems. The externally mounted high pressure pump is capable of supplying 15.9 gallons of fuel an hour. System pressure is controlled by a pressure regulator mounted on the engine.
Jul 5, 2010 at 12:05 PM
