When you first start the truck it runs good but when you drive it it will start stalling out going down the road and shut off. When I restart it it will sometimes take 5-6 times for it to keep running. The motor will rev between 500-1100 rpms and then shut off. i have replaced the fuel filter, IAC, O2 sensor, and the ignition coil but nothing has changed. Could it be the fuel pump?
Mar 27, 2010 at 8:56 AM
