Surging usually means an intake manifold leak, either under the throttle body, or the intake itself. Using propane tool hunt for the leak, then when engine smoothes out, you have found it. EGR opening at the wrong time can be a problem too, check the EGR solenoid, it's got vac and an electrical connector on it, called EVR.
SPONSORED LINKS
Wednesday, June 3rd, 2009 AT 2:55 AM
