1989 Ford Bronco acceleration problems
259,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRIGHT9431
I have a ford bronco II I have recently been having problems with the acceleration. I will stop for a red light or stop sign, and when I push on the acceleration pedal the vehicle acts like it is in nuetral. What is causing this and what can be done to repair this?
Sep 30, 2008 at 8:10 AM
MERLIN2021
  • 17,250 POSTS
Maybe it is! The tranny may need work, or it's low on fluid...check the level on flat ground, warm engine. Fluid should be pink, not brown and burnt smelling.
Sep 30, 2008 at 8:31 AM
