1989 Ford Bronco 1989 Bronco II electrical whine and no sta
1989 FORD BRONCO
68,030 MILES • 6 CYL • 4WD • MANUAL
DRAKKARI
I just recently left the lights going on my truck overnight. When I went to start it in the morning obviously it would not start. I got a jump from someone and it still wouldn't start. So I swapped in a newer battery from my '69 Mustang and it still wouldn't start. I replaced 2 blown maxi fuses in the engine compartment labeled "alt pwer 1 and alt pwer 2" to no avail. Please help me if you can.
Thanks,
Roger
May 9, 2009 at 2:07 PM
  • 110,244 POSTS
IS the starter working? If so, are you getting spark and fuel to the engine?
Jun 4, 2009 at 3:58 PM
DRAKKARI
The starter is working and there is fuel (I checked the valve on the fuel rail). I haven't checked spark yet since I have been busy but I noticed that none of the relays are clicking when I turn the key to the On position.
Thanks,
Roger
Jun 15, 2009 at 11:05 AM
  • 110,244 POSTS
Let me know when you get to check for spark.
Jun 15, 2009 at 12:46 PM
DRAKKARI
I am not getting any spark at the moment. I checked the relays and 2 out of 3 were clicking so I replaced them. The fuel pump still will not turn off as long as the key is in the ON position.
Thanks,
Roger
Jun 16, 2009 at 3:53 PM
