333000 miles, sounds like the rods and mains are spent (bearings) and possibly the wristpin bearings. At this point its cheaper to replace the engine. Maybe be a sticky lifter, but being such high mileage, id put my money on a bearing. Pull the oilpan to see if you spun a bearing. At that point, check the condition of the bearings. If you see copper, they are junk. Should turn the crankshaft, and get new bearings, but keep in mind mileage. I suggest a new engine.
SPONSORED LINKS
Tuesday, September 14th, 2010 AT 9:51 PM
