1988 Ford Bronco will not turn over
RETIREDMIKE
  • 1988 FORD BRONCO
Engine Performance problem
1988 Ford Bronco V8 Four Wheel Drive Automatic 0
new motor, crnk by hand ok, now in the truck can nto turn by hand or starter
Sunday, November 9th, 2008 AT 2:43 PM
POLISHMAFIABOSS
  • 27 POSTS
If the engine is in the vehicle with the torque converter and transmission installed and it will not turn over either by hand or with the starter, check the torque converter 1st. (Should've replaced it when you rebuilt the motor.) When you go to check the torque converter, try to spin the motor over when you break the transmission away from the motor, that'll give you and idea as to which of the 2 it could be.
Wednesday, January 21st, 2009 AT 4:32 PM
