1988 Ford Bronco - Valve Job
DIVERDAN
I have a 1988 full size ford bronco, 302 fuel injected, 90K miles. I have confirmed that I have ZERO compression in cylinder 8 and I am about to pull the heads to do a complete valve job. (another mechinic confirmed I have a burnt valve) My questions are this. If I stage the engine at top dead center, do I still have to remove all the rocker arms, springs, rods , etc before I pull the heads, or will TDC take the tension off the springs? should I also pull the intake maniford and replace the lifters as well? During this valve job do you recommend that I replace all the rocker arms, rods, and springs or use the same already in place?
This is a hobby for me, not a profession and I can find the Torques, etc in the regular chilton's manual for repairs. Do you also suggest I pull the engine for this job? I plan a full restoration on this 4 wheel drive vehicle and will also put a lift kit on it. I am thinking about a 6 inch lift. If you have a package for the lift kit, let me know, but I have to fix the engine problem first. I have already repainted the vehicle and look forward to getting this job done when I get back in the states. Thankx for your help and I WILL make a donation. - Dan
Please respond directly to smpd212 at yahoo dot com as well as a response here[img:3762e98731]http://www.2carpros.com/forum/automotive_pictures/99731_Bronco_1.jpg[/img:3762e98731]
. I am currently in Baghdad and rarely get on the net, but can check my mail regularly.
Sep 13, 2007 at 5:44 AM
  • 75,988 POSTS
Welcome to 2carpros
My kind of Bronco-it'll be nice if you can dump in a 460 in it. About the top side-pull the engine and get comfortable while doing it standing-the shortcut way is a backbreaker.
Put the engine on no.1 compression stroke-make sure the piston is all the way up. Then yank it out,Pull the heads and get a complete valve job have the machinist decide what needs to be replace.
About the head just loosen the rocker arms to relief the spring tension-makes sure you mark everything where one goes to where-
You take care and keep your head down and God bless you freedom fighter.
Good luck
Sep 14, 2007 at 8:35 AM
DIVERDAN
Thanks Raxmataz, can you recommend the best manual for this job and also an engine stand? I will order them now and have them delivered by the time I get home. I have a overhead winch in the shop large enough to pull the engine, but would like a stand. The picture below is when I first picked it up and before the body and paint work.
https://images.2carpros.com/forum/automotive_pictures/99731_Bronco_Before_1.jpg
Sep 14, 2007 at 4:03 PM
  • 75,988 POSTS
[/quote:162787b924] Okay Navyseal Dan-its better a nut behind the wheel than a beer can lol. My advised is get a service manual for that model/year and for the stand a seal can make anything lol its about maybe $100 or less- BTW below the posts you'll see something about buying manuals-if you need me holler You take care and keep your stuff wired we'll be waiting for you to come home-God bless you and tell the Guys and Gals 2carpros appreciates it. Freedom is not cheap I've been there before in Vietnam Good Luck
Sep 14, 2007 at 5:21 PM
DIVERDAN
[/quote] Okay Navyseal Dan-its better a nut behind the wheel than a beer can lol. You take care and keep your stuff wired we'll be waiting for you to come home-God bless you and tell the Guys and Gals 2carpros appreciates it. Freedom is not cheap I've been there before in Vietnam Good Luck[/quote] Well, not exactly a Navy Seal, more in the line of former airborne infantry, 20 year retired cop now doing diplomatic security. Thanks, brother! As you can see I am a visual person :)
https://images.2carpros.com/forum/automotive_pictures/99731_Dan23_1.jpg
Sep 14, 2007 at 7:00 PM
  • 75,988 POSTS
[/quote] Seal or No Seal I see an american and I know you're not from there lol.you holler when you need more info. You hea! Take care Bro...
Sep 14, 2007 at 8:46 PM
