1988 Ford Bronco thermostate gauge
PENSO1018
Engine Cooling problem
1988 Ford Bronco V8 Four Wheel Drive Automatic
what could be the reason on an 1988 5.8 ford bronco that thermostate gauge dosnt read?. How to I fix this problem.
Dec 2, 2008 at 1:11 PM
DAVE H
  • 13,383 POSTS
ENGINE COOLANT TEMPERATURE (ECT) SENSOR
The ECT is mounted in the block or manifold to monitor engine coolant temperature. A signal is transmitted to the ECA, throughout the entire range of operating temperatures. In turn, the ECA adjusts air/fuel mixture, ignition timing, and EGR operation. On models equipped with electronic instrument cluster, ECT output is also used to control the coolant temperature indicator.
Dec 3, 2008 at 1:08 PM
