1988 Ford Bronco Cold Stalling
TAVINJIM24
I am having a problem with my Bronco stalling when cold and while driving the freeway the power seems to sputter minimally. It usually stalls when I start the truck up and put it into gear. I recently had a refurbished engine installed but this problem was happening before and continues with the new engine. I have basically replaced everything on the engine with new parts from sparkplugs to a new EGR valve. I have taken it to a mechanis shop and they can not figure out why the engine would do this. I am thinking it is something electrical since it is EFI. Any advice would help since i have tried all i can think of.
Oct 10, 2007 at 4:31 AM
BLACKOP555
  • 10,386 POSTS
the temp sending unit could be sending the wrong temp to the ECM causing it to mix the fuel wrong causing it to run improperly
Oct 18, 2007 at 1:39 PM
BLACKOP555
  • 10,386 POSTS
also try cleaning the MAS
Oct 18, 2007 at 1:46 PM
Suggested Repair
Check the coolant temperature sending unit for incorrect readings to the ECM, and clean the mass air sensor (MAS).
Conversation Summary
The owner of a 1988 Ford Bronco reports stalling when cold, especially after starting and shifting into gear, plus slight sputtering on the freeway. The problem continued after a refurbished engine and replacement of many parts, including spark plugs and the EGR valve. An expert suggested a faulty temperature sending unit could cause the ECM to mix fuel incorrectly and recommended cleaning the mass air sensor.
