1979 Ford Bronco engine will not stay running
BIGWALLY
  • 1979 FORD BRONCO
  • V8
  • 4WD
  • MANUAL
  • 12,700 MILES
79 bronco. New fuel pump, rebuilt carb, will start upon cranking then die as if no gas, when you pump it during cranking it goes. Brum brum brum and dies, fuel level in carb is correct. No fuel line collapse, recently cleaned gas tank, new cap and rotor, plugs and wires. Recently died on the road and restarted by itself upon coasting. Engine was rebuilt 46,000 mi ago
Sunday, January 13th, 2008 AT 12:51 AM
Gunny, I need the pick-up coil resistances on a 1996 dodge pick-up distributor any pick up will do-am on a notebook cannot acess it-wil you pretty please! Good Boy thanks Homie send it PM
Sunday, January 13th, 2008 AT 6:29 PM
