1988 Ford Bronco R & R Water Pump
DDWWCC
Engine Cooling problem
1988 Ford Bronco 6 cyl Two Wheel Drive Automatic
How do you remove the fan from the pulleys? There is a nut between the fan and pulley. Do you hold the pulleys with a strap wrench and turn the nut to unscrew the fan? And if so which way is the nut threaded on?
Jul 10, 2008 at 4:15 PM
OBXAUTOMEDIC
  • 3,711 POSTS
You will need these Specialty Tools.....
https://images.2carpros.com/forum/automotive_pictures/188069_24947_3.jpg
Jul 11, 2008 at 12:56 AM
