1988 Ford Bronco Oil and antifreeze
1988 FORD BRONCO
DUSTINANTES
Engine Cooling problem
1988 Ford Bronco 6 cyl Four Wheel Drive
Changed head gasket to spec and the oil and antifreeze are still mixing where else could this problem be caused
Feb 8, 2010 at 2:13 PM
TOOOMANYTOYS
  • 513 POSTS
Did you check the heads for warpage or cracks. Also might have to check engine block for cracks too.
Feb 8, 2010 at 2:15 PM
