1988 Ford Bronco Not sure?
1988 FORD BRONCO
90,000 MILES • 6 CYL • 4WD • AUTOMATIC
FOOLISHWAYS
I changed the radiator hose, flushed the radiator,changed the oil, filter and all, and fuel pump. It will run okay for alittle while though when i go to play in some mud i put it in 4 high or low and it overheats fairly quickly. Could this be the water pump or is there another answer to this?
Aug 25, 2009 at 1:50 AM
MERLIN2021
  • 17,250 POSTS
Hows the clutch fan working? The hotter it gets, the tighter(hard to spin) the blades? Check the resistance by spining it cold, then hot, if no change, replace it!
Aug 25, 2009 at 3:27 AM
