Engine Performance problem
1988 Ford Bronco V8 Four Wheel Drive Automatic
The vehicle has smooth to rough idling when in park. when the vehicle is put in drive it wants to lunge with your foot on the brake almost stalling the vehicle. iac, coolant temp sensor, ecu, have been replaced. Fuel pressure was tested reading around 40psi. any thoughts?!?
Nov 11, 2009 at 6:45 PM
