1988 Ford Bronco headlights blinking
101,000 MILES • 6 CYL • 4WD • AUTOMATIC
SIXPACK37311
have replaced headlight switch and dimmer switch headlights still blink any help?
Dec 12, 2009 at 5:49 AM
BLACKOP555
  • 10,386 POSTS
what you mean flash. inside lights, outside lights? indicators? when do they flash. give me as much as you can
Dec 12, 2009 at 11:21 AM
SIXPACK37311
headlights parking lights dask lights all blinking have replaced headlight switch and dimmer switch sitll blinking after about 2 min
Dec 12, 2009 at 2:55 PM
BLACKOP555
  • 10,386 POSTS
check the wiring harnesses for both switches and make sure they are not damaged internally. check and make sure the grounds for your lighting system is tight and free of corrosion.
Dec 13, 2009 at 3:12 AM
