Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Bronco
Fuel System
Fuel Level Sensor
Replace/Remove
1988 Ford Bronco fuel system sensors
1988 FORD BRONCO
165,000 MILES • V8 • 4WD • AUTOMATIC
DESKTOP
MEMBER
1 POST
Does it burn up relays if the system is dirty and should I go ahead and replace every single system component?
Aug 5, 2009 at 9:56 AM
BLACKOP555
Experienced Mechanic
What are yoasking? if the sensors are bad would they burn out a relay?
only way that would happen is if it was shorted to power and caused it to overheat, but that would ususally blow the pcm
Aug 12, 2009 at 12:35 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
