1988 Ford Bronco fuel system sensors
1988 FORD BRONCO
165,000 MILES • V8 • 4WD • AUTOMATIC
DESKTOP
Does it burn up relays if the system is dirty and should I go ahead and replace every single system component?
Aug 5, 2009 at 9:56 AM
BLACKOP555
  • 10,386 POSTS
What are yoasking? if the sensors are bad would they burn out a relay?
only way that would happen is if it was shorted to power and caused it to overheat, but that would ususally blow the pcm
Aug 12, 2009 at 12:35 PM
