1988 Ford Bronco fuel freeze
TRENTCRO
Engine Performance problem
1988 Ford Bronco V8 Four Wheel Drive Manual
my 88 bronco froze up at a gas pump in minus 14 degree wheather. it has since been towed home and warmed up and it still wouldnt start. so i replaced the spark plugs, cap, rotor, and plug wires. i have also put two bottles of heat and ten gallons of fresh high octane gas. still it wont start. if i step on the gas while starting i can get it to chug a little but fuel runs out the exhast
is the fuel pump gone bad or something else
Dec 29, 2008 at 5:59 AM
BLACKOP555
  • 10,386 POSTS
before replacing anything else you will have to check for spark on ALL cylinders, be sure to use a spark tester and make sure its grounded out to a good clean ground.
observe the spark characteristics, should be bright and blue and well defined, sharp looking like lightning. should also be rhythmatic not firing like a machine gun.
next step would be to check the fuel pressure at the fuel rail wiht a fuel pressure check guage.
is it a EFI model? the 88's some were carbed but most were EFI.
Dec 30, 2008 at 1:26 AM
TRENTCRO
yes it is an efi model and i have got it to run but i can only get it to run with the crash fuel shut off switch disconnected. how could this be that switch should cut all power to the to both fuel pumps. i ran it this way for one hour and it still didnt stall out, like the book said it would.
and it used a hole lot of gas in that one hour
Dec 30, 2008 at 11:46 AM
