1988 Ford Bronco engine won't start
68,000 MILES • V8 • 4WD • AUTOMATIC
INTIMINATOR99
engine is 5.0 crate, during u-turns bronco will sometimes stop running. Usually would re-start. The last time went completely dead. I replaced ignition lock in steering wheel. Still no start, replaced fuel pump relay and starter solenoid. Replaced two fusable links at starter sol. (fuel pump and alternator) Turns over but still will not start. Also every time I connect alternator to neg post on starter solenoid the fus. link melts. Does the alternator wire connect to positive side? Any help would be great.
Oct 13, 2008 at 6:58 AM
RENAUDTN
  • 636 POSTS
Have you checked your fuel pressure?
Oct 20, 2008 at 3:28 AM
