1988 Ford Bronco engine stallin out when engines hot!!
1988 FORD BRONCO
185,000 MILES • V8 • 4WD • AUTOMATIC
SHANEDALTONBRONCO
when im driving down the road about 15 mins after i fire it up the trucks oil pressure drops really low and the engine light comes on and it starts to spit and sputter i just replaced the following: spark plugs and wires,fuel regulator, distributor module, fuel relay, fuel filter,distributor cap,rotor button, alternator. i ran fuel injector cleaner threw it.
the fuel rail pressure rail was at 13.5-29 psi and it fluctuated and stalled then cut off
what could the problem be please help
Jun 2, 2010 at 12:25 PM
If its the CEL/SES/MIL coming on you have a problem within the engine management system-you need to scan the computer for codes. this is your starting point finding out what's going on.
Jun 2, 2010 at 10:06 PM
