1988 Ford Bronco engine flooding
170,000 MILES • V8 • 4WD • AUTOMATIC
COMPUTERG185
my bronco has problems starting after it has been started once it will just keep turning over and smelling like gas if you give it wide open throttle for 30 to 45 seconds it will start during the no start i checked spark and fuel and comprestion all are good i have replaced coolant temp sensor o2 sensor and tps sensor im lost on where to check next
Feb 8, 2010 at 6:08 AM
  • 75,988 POSTS
Check and test the fuel injectors and the fuel pressure regulator
Feb 8, 2010 at 7:10 AM
COMPUTERG185
the fuel presure regulator is good how do you check the fuel injectors thank you
Feb 9, 2010 at 5:02 AM
  • 75,988 POSTS
Try running an injector cleaner thru the system-don't work its got to come out and get flow tested-
Feb 9, 2010 at 5:57 AM
