1988 Ford Bronco cant figure this out
PDACK
1988 Ford Bronco 6 cyl Four Wheel Drive Manual
I have an '88 bronco II it would just stall out once and awhile but start up soon after. i was going down a dirt road and it stalled but wouldnt start again. i got it home and it would run for a minute and then nothing for the rest of the day. Now it wont even do that. i get spark, both fuel pumps were replaced, fuel filter, fuel pressure regulator. i'm stumped, any help would be greatly appreciated. Please and Thank You
Feb 14, 2010 at 4:15 PM
  • 75,988 POSTS
Verify the fuel pressure by checking it with a fuel pressure gauge if its within specs and make sure the injectors are pulsing and its still getting spark if all okay-check the valve and ignition timing
Feb 14, 2010 at 4:52 PM
PDACK
i checked the fuel pressure, i turned the key on and it went up a little and then turned it off and on again and it went up some more untill it was up to temp. I have no clue what that means.
Feb 17, 2010 at 11:14 AM
  • 75,988 POSTS
What's the fuel pressure reading?
Feb 18, 2010 at 1:54 AM
PDACK
the fuel pressure goes up to 45 and drops to like 35 while cranking so thats good. im still getting good spark. i used a code reader and it said it has low throttle position sensor voltage but i dont know what that means or if that will stop it from running.
May 5, 2010 at 2:32 AM
