1988 Ford Bronco Brake lights
130,000 MILES • 6 CYL • 4WD • AUTOMATIC
LONGABAUGH
The brake lights will only work when i apply pressure to the brakes and when i turn on the blinker also my interior dash lights will not light up i checked the fuse and it looks good i dont know what to do.
Jan 10, 2009 at 9:19 AM
BILLYMAC
  • 2,204 POSTS
do you mean tail lights .normally the tail lights and dash lights will both be out if one is.check and see if you have power when the head light switch is on at the fuse for tail lights.if yesprob in harness going to rear if no the switch. if you have more questions please ask. please don,t forget to vote on my answer.ty billymac
Jan 16, 2009 at 8:35 AM
