1988 Ford Bronco bearing replacement
180,000 MILES • V8 • 4WD • AUTOMATIC
DMEYER16
I have a 1988 Ford Bronco. My bearings went out so i pick up new ones. when I took the pull off hub off, the bearings all fell out for the outer i think it is. i cant get the bearing racers off. it looks like its stuck on the spindle i think. im not really too sure how im suppose to go about this.
Aug 26, 2010 at 6:33 PM
BLUELIGHTNIN6
  • 16,542 POSTS
not sure which bearings you're working on but most likely they will need a press or slide hammer and puller to replace them.
Aug 27, 2010 at 11:40 AM
