1988 Ford Bronco
AGNITSCH
  • 1988 FORD BRONCO
1988 Ford Bronco V8 Four Wheel Drive Automatic
i am working on a 1988 bronco. It wont start. I nave spark. I have fuel to the fuel rail. It is like the injectors are not working. The injectors also have power to them with the ignition off
Friday, January 2nd, 2009 AT 3:09 PM
Disconnect the EEC Power relay and check again for power at the injector/s do you still have it?
Power to the injectors but not pulsing could be the computer ground driver circuit at fault
Friday, January 2nd, 2009 AT 3:21 PM
