1988 Ford Bronco
AKLITE
  • 1988 FORD BRONCO
Engine Mechanical problem
1988 Ford Bronco V8 Four Wheel Drive Automatic
I drove it to work one morning, turned the corner, and it died. Plugs, wires, air filter, cap & rotor, fuel filter, also replaced the distributor, ignition coil, ignition modulator, and new battery. And still doesn't start.
Sunday, June 14th, 2009 AT 11:02 PM
JEHUSAFAT
  • 27 POSTS
Check for spark fuel pressure or even power to injectors
Saturday, August 1st, 2009 AT 2:35 AM
AKLITE
I have no spark, now what?
Friday, August 7th, 2009 AT 12:59 AM
JEHUSAFAT
  • 27 POSTS
Ok I looked at everything you replaced there is an ignition switch on the steering column if they are bad your ignition system usually wont work did you replace the entire distributor or just the cap and rotor. The ignition switch is only like 10 bucks at parts store
Friday, August 7th, 2009 AT 10:13 AM
AKLITE
I changed the whole distributor, its a brand new one.
Monday, August 10th, 2009 AT 9:56 PM
