1988 Ford Bronco
JIM MUELLER
  • 1988 FORD BRONCO
Engine Mechanical problem
1988 Ford Bronco V8 Four Wheel Drive Automatic
UNIT GOES FROM AN IDLE THEN ATFER A LITTLE BIT IT S RPM GO UP TO 3000 AND STAY THERE
Friday, November 13th, 2009 AT 9:56 PM
  • 109,755 POSTS
Has the check engine light ome on? To me, it sounds like a bad throttle position sensor or idle air control valve, but that is a guess without a code from the computer.
Let me know about the light.
Saturday, November 14th, 2009 AT 11:51 PM
