1987 Ford Bronco smell and condesation
LIFFALOU
  • 1987 FORD BRONCO
Heater problem
1987 Ford Bronco Engine Size unknown Four Wheel Drive Automatic 122000 miles
when I turn the heater on in my bronco 2 air is moving thru but this terrible smell comes thru the vents. It smells like hamster cage and the windows are all fogged up.I noticed a white cloudy vapor coming thru the vents as well. What is the issue and how can I get it fixed?
Friday, January 4th, 2008 AT 1:20 PM
BLACKOP555
  • 10,371 POSTS
Sounds to me like a bad heater core, and I belive you are in luck, I belive it is located right behind the glovebox on your model! That makes a 7 hour job a 30 minute job!
Friday, January 4th, 2008 AT 8:22 PM
