1986 Ford Bronco Heater and overheating issues
60,000 MILES • V8 • 4WD • AUTOMATIC
BROKENBRONCO
The engine runs hot, but the heater blows cold. I've replaced the thermostat, and flushed the radiator. Could it be a wiring issue?
Jan 21, 2009 at 2:42 AM
  • 110,248 POSTS
Hi:
It sounds like the radiator is still plugged. You may want to consider having it rodded out. Sometimes spraying water through it isn't enough.
As far as the heat, are both heater core hoses getting hot when the engine is hot, running and the heat is on?
Jan 22, 2009 at 12:36 PM
