i have an 87 full size bronco it runs fine when driving it but when you stop and shut it off it will not start again. i have done a tune up on it and that did not fix the problem. i have 42lbs of fuel pressure with the engine off and about 32 while it is running. the fuel pressure is the same when it is hot and wont start. i also just had the tfi module checked and it is good. i am getting spark when it is hot and fuel just no start. is there somthing i am missing? please email me at brian.tucker.bt@gmail.com
Mar 24, 2010 at 2:58 PM
