1987 Ford Bronco Possiible coolant in oil.
JOKER84088
Engine Performance problem
1987 Ford Bronco V8 Four Wheel Drive Automatic unknow miles
Ok this is going to be a multipart question. 1) How would i tell if there is coolant in my oil? 2) My truck '87 Bronco has a hard staying running when i first start it, and there is usually white smoke at first start up, what/why could that be? 3) When idling at stops it acts like it wants to die, what could cause that?
I really hope you can help me out.
Mar 21, 2008 at 6:53 PM
  • 75,988 POSTS
White smoke during initial cold start could be caused by condensation and also not warming engine up properly before moving it.
How to tell if it has water-get a aluminum foil pull the dipstick or drain a little and put some on the foil heat it up if it starts crackling it has water make sure its not just condensation/moisture.
Mar 21, 2008 at 10:38 PM
