1987 Ford Bronco oil pressure
15,000 MILES • V8 • 4WD • AUTOMATIC
PREMIERPET
hello,
my bronco seems to run fine but the oil pressure runs pretty low. when its cool the needle runs at the low normal and when its warmed up and you let it idle it will run at the bottom line and the engine light comes on. it uses very little oil and does not smoke
Jul 23, 2009 at 2:55 PM
  • 75,988 POSTS
Do you have any type of knocking noises such as a thudding/thumping if not check the oil pressure with a mechanical gauge to determine if its the oil pressure switch, oil pump and engine bearings-
Jul 23, 2009 at 3:06 PM
