1987 Ford Bronco not getting fuel
1980IMPALA
1987 Ford Bronco 6 cyl Four Wheel Drive
well i am stumped. i went through the fuel system and the pump in the tank works the pump on the frame works fillter is clean put a new fuel pressure regulator on it that was not it, i thought the injectors so i put some on it still no start. but when i spray starter fluid in it it starts untill it uses the fluid up and i checked the gas and it was still good can you help me?
Mar 20, 2010 at 5:52 AM
  • 75,988 POSTS
Verify the fuel pressure if its within specs if okay injectors might not be pulsing
Mar 20, 2010 at 8:27 AM
