1987 Ford Bronco Normal PSI for cylinder compression test
130,000 MILES • V8 • 4WD • MANUAL
AUSTIN1993
The engine loops at idle speed.
What are the specifications for the cylinder compression?
Jul 8, 2009 at 3:09 AM
BLACKOP555
  • 10,386 POSTS
as long as its over 100 and the lowest cylinder is no more then 30% less then the highest.
i.e highest is 100 lowest has to be 70 or more.
i would suspect a vaccum leak causing your problem.
to check it spray the vaccum lines with brake cleaner and monitor the idle. if idle changes thers a leak. also spray the gaskets and air intake hose also
Aug 12, 2009 at 1:15 PM
