1987 Ford Bronco new starter is sluggish
130,000 MILES • V8 • 4WD • AUTOMATIC
CHRISGAUDETTE
i replaced starter and battery and the problem went away temporarily. after truck heats up the starter has a hard time turning the motor. the battery is new and if i put a jump to the battery the truck will turn over fine and start with no problem i also found that if i let the truck cool down the truck will start the starter is new
Dec 26, 2009 at 5:13 AM
  • 75,988 POSTS
Drop the starter and get it load tested,if ok check and test the starter relay.Do a voltage drop test on the positive and negative battery cable.
Dec 26, 2009 at 11:12 AM
