1987 Ford Bronco Multifunction Switch Location
261,000 MILES • 4 CYL • 4WD • AUTOMATIC
USAF_PMS_06
I have a 1987 Ford Bronco II. I just recently bought this wonderful pick-up and have been upgrading it since day one. However I have no brake lights. I noticed there was no fuse in the slot for the stop lights, and when i replaced it pressing the brake with the truck off the fuse popped, and when i replaced that fuse and turned the hazards on I got the same result. So I obviously have a short some where. Shooting to ground was good, both bulb housing contacts were shorted together. Using a wire diagram i belive my Multifunction Swtich is bad. However I have no idea where this switch is at. Do yall know where the multifunction switch on a 1987 Ford Bronco II is? Thank you for your help.
Mar 28, 2008 at 6:05 AM
MERLIN2021
  • 17,250 POSTS
This is the turn signal switch...
Mar 28, 2008 at 6:19 AM
