1987 Ford Bronco injector problems
1987 FORD BRONCO
80,000 MILES • V8 • 4WD • AUTOMATIC
FORD BEASTE
i have an 87 bronco that bought from a friend for cheap. it hasn't run in 4 years and has been sitting in a barn. it was running perfect before it died. i've checked all the regular things it has compression fuel to the rails and spark. all pressures are good. i checked the injectors with a test light on the harness and had power did not mesure with multimeter. i got a noid light tester and tried using that but got nothing from that. wat do you make of the situation.
Apr 26, 2009 at 11:12 AM
Check the EEC Power relay it powers the injectors if okay could be coming from the computer injectors ground drivers
Apr 26, 2009 at 11:50 AM
