Ignition Switch
1TAILTASTER
Electrical problem
1987 Ford Bronco V8 Four Wheel Drive Automatic 200.00 miles
When i turn the ignition switch to the "start" position, the truck will start. But when i release the switch and it returns to the "power on" position the truck dies. I first noticed this when the radio and the elect. windows would not operate unless i keep a foward motion on the key switch. Not to the "start" position but to the "power on" position. I have removed the steering wheel, replaced the key switch, cleaned and lubricated all mechanical parts and cleaned all electricial contacts. My grandson is giving me a fit about not takeing him fishing, so please help me exorcise this demon.
Feb 27, 2009 at 3:45 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Sounds like your fusible links up by the starter solenoid have gone bad just tug on them to see if one is rubbery. Here is the location also check by the starter solenoid.
Check for power at the ignition switch and through the fusible links
Check out the diagrams (Below)
Please let us know what you find.
Cheers
Feb 27, 2009 at 3:49 AM
RICK DAVIES
Bronco won't stay started. When I turn the key to the start position, it stays on. Once I release it to the run position, it shuts off. Since the issue I have changed the battery, the solenoid, resistor, ignition switch, the starter, and the ignition cylinder (where the key goes). I am at a loss here. Would it be easier to just replace the distributor, distributor cap, and module instead of pulling it all apart like that? My mechanical skills are limited.
Please help....
Thank you,
Rick
Mar 2, 2018 at 5:38 AM (Merged)
if you loosen the distributor and turn it towards you, you will not have to remove it. just make sure you mark where it was for the timing.
roy
RICK DAVIES
These are all great suggestions. I will be working on it with in the next couple of days and will get back to you?
THANK YOU
RICK DAVIES
I changed the modulator bolted on the drivers side of the engine compartment. FIXED THE PROBLEM. Thanks guys
MAKGABENV
I’ve changed engine modulator as well.
Your welcome.
MAKGABENV
I’m changing my steering column.
Mar 23, 2018 at 9:51 AM
  • 55,684 POSTS
You must check for power through the fusible links check the fist post in this thread.
Mar 26, 2018 at 11:20 AM
