1987 Ford Bronco Horn
1987 FORD BRONCO
SSGWALDEN
1987 Ford Bronco
How do you wire a horn when there is not a horn already in the truck?
Feb 8, 2009 at 7:07 AM
BLACKOP555
  • 10,386 POSTS
what kind of horn? and are you trying to hook it up to a button mounted on the dash?
does the horn have one wire, two wires?
Feb 16, 2009 at 1:04 AM
SSGWALDEN
It is an eletric horn that says it can be hooked up with one or two wires. Yes I am tring to hook it up to a push button on the dash.
Feb 16, 2009 at 3:29 AM
BLACKOP555
  • 10,386 POSTS
you can either run the ground wire to the battery or use the horn itself as teh ground.
then run a live wire from fuse box to your button and other side to the one wire on the horn.
Feb 22, 2009 at 10:55 AM
