Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Bronco
Exterior Light
Headlight
Not Working
1987 Ford Bronco head lights won't work on my Bronco II
1987 FORD BRONCO
38,000 MILES • 6 CYL • 4WD • MANUAL
DANIELCUTHBERT
MEMBER
1 POST
I checked the fuses, their fine. What could it be, the parking lights and all other lights work fine.
Apr 29, 2009 at 11:47 AM
BLUELIGHTNIN6
Experienced Mechanic
Check for power at the headlight switch. If power is OK suspect faulty switch. If power is not OK, inspect wiring for damages/shorts.
Thanks for using 2CarPros.com!
Apr 29, 2009 at 5:58 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
