1987 Ford Bronco has a miss all the time
BENHAMJIM
  • 1987 FORD BRONCO
  • 6 CYL
  • 4WD
  • 136,000 MILES
My emission light came on and it started missing about the same time. Changed plug's and wires, new fuel-injector, new coil, rotor-button and cap. New fuel pump(the one in the tank) fuel-filter, new battery, and new computer. Also done compression check on all 6 cyliders and they checked out perfect. Now, after doing all that, when I drive it, it looses power, to the point that, even floored, wont gain any speed.
Thursday, June 3rd, 2010 AT 2:32 PM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Thursday, June 3rd, 2010 AT 6:07 PM
