1987 Ford Bronco Fuel rail pressure
GBRAD1380
Engine Performance problem
1987 Ford Bronco V8 Four Wheel Drive Automatic
Just replaced the tank pump (old one was shot) Before replacement, the pressure was about 50 psi for the few minutes it would run before quitting. With new tank pump, the rail pressure is now 80psi. This seems a bit high to me. Anybody know what the correct pressure should be??
Dec 13, 2008 at 10:51 AM
DAVE H
  • 13,383 POSTS
FUEL PUMP SPECIFICATIONS
ApplicationSpecification
High Pressure
Pressure ..........50-60 psi (3.5-4.2 kg/cm2 )
Volume .35 pint (.17L) in 10 seconds
Low Pressure - Volume.....1 pint (.47L) in 10 seconds
Dec 13, 2008 at 11:21 PM
