1987 Ford Bronco engine wont start
JEHUSAFAT
  • 27 POSTS
Engine Mechanical problem
1987 Ford Bronco V8 Four Wheel Drive Automatic
i have a 1987 ford bronco full size with a 302 fuel injected been trying to get it to run for past few weeks and cant figure it out i have replaced ignition coil cap and rotor fuel filter fuel pump wires and plugs cleaned injectors and replaced fuel pressure regulator i have been having problems trying to start this bronco i have hooked both pumps up to a switch so i can turn them on manually engine will start real quick but will die a couple seconds later truck had been in an accident will start up fine with starter fluid but dies once it is used up it has an inertia switch on it have replaced almost everything to do with fuel and ignition any help would be greatly appreciated thankyou
Jul 22, 2009 at 6:29 PM
  • 75,988 POSTS
Check the fuel pressure and injection pulses.
Jul 22, 2009 at 8:12 PM
  • 75,988 POSTS
Check your PM's its in there as requested
Jul 26, 2009 at 7:07 AM
  • 75,988 POSTS
Do you hear the fuel pump come on if not -check the inertia fuel cut switch if its tripped
Jul 26, 2009 at 11:42 AM
JEHUSAFAT
  • 27 POSTS
no i do not hear the fuel pumps engage i can hear inertia switch click
Jul 26, 2009 at 4:12 PM
  • 75,988 POSTS
Check for power both side of the inertia switch.
Jul 26, 2009 at 5:20 PM
JEHUSAFAT
  • 27 POSTS
ok i did check i do have power to both sides of inertia but still the fuel pumps dont engage when key is turned to run i have hooked both pumps up to a switch to turn them on manually and can hear them running
Jul 26, 2009 at 5:31 PM
  • 75,988 POSTS
When power leaves the inertia switch it goes straight to the fuel pumps it should come on -double check the wiring/ground
Jul 26, 2009 at 5:35 PM
JEHUSAFAT
  • 27 POSTS
hey i lied i cannot hear the intank fuel pump going
just the one on the rail
Jul 26, 2009 at 6:01 PM
  • 75,988 POSTS
Fine power it up and see what happens from the battery
Jul 27, 2009 at 7:41 AM
JEHUSAFAT
  • 27 POSTS
i tried to start up the fuel pump and it is not working
would that be the problem possibly gas not running through it
Jul 27, 2009 at 8:29 AM
  • 75,988 POSTS
It has to work to push fuel to the other one.
Jul 27, 2009 at 8:55 AM
JEHUSAFAT
  • 27 POSTS
alright yeah i bought a new pump will install tomorrow and let you know i also have to do the timing thanks forall the info if it does not work illlet you know
Jul 27, 2009 at 6:42 PM
JEHUSAFAT
  • 27 POSTS
hey i appreciate all the help nothing i do is getting it torun i am just selling it thanks again for the help
Jul 29, 2009 at 9:53 AM
JEHUSAFAT
  • 27 POSTS
hey just wanted to let you know i tried a couple more things everything is brand new on the bronco even had the timing done and it just wont start andhave just decided to sell the damn thing thanks for the help
Jul 31, 2009 at 7:14 PM
