Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Bronco
Engine
Starter
Replace/Remove
1987 Ford Bronco electrical problem
1987 FORD BRONCO
17,000 MILES • V8 • 4WD • AUTOMATIC
JRMOO
MEMBER
1 POST
I changed the starter and battery, when i hooked up the battery the starter engaged by itself without key in the ignition
Nov 29, 2009 at 8:53 AM
BIGJIM79
MEMBER
The starter solenoid is stuck. Its on the inner finder on the pasenger side.
Dec 1, 2009 at 12:55 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
