1987 Ford Bronco could this be a bad computer?
1987 FORD BRONCO
280,000 MILES • V8 • 4WD • AUTOMATIC
MWILLIAMS4285
i have replaced alot of things including distirbuter rotor iac all vacum hoses both fuel pumps replaced gaskets new fuel filter air filter. right at startup it idles weird for about thirty seconds then its fine but when i put it into gear and start to accelerate it hestitates some times it stalls and other times it keeps on moving and then it misses at high speeds and sometimes jerks alot at high speeds i have also gotten timing fixed and idle fixed. i have also changed all plugs wires and fuel pressure regulator and vacume regulator new alternator also
Jun 19, 2010 at 8:44 AM
Check and test the engine coolant temperature sensor, throttle position and mass airflow sensor to include the EGR valve
Jun 19, 2010 at 9:07 AM
