1987 Ford Bronco clutch
1987 FORD BRONCO
CHUKIE
Transmission problem
1987 Ford Bronco 6 cyl Four Wheel Drive Manual
ive just installed a whole new clutch kit, new flywheel clean the tranny, new clutch master cylinder. the problem im having now is when i push the clutch in the gears do not go in its not slipping, it just simly will not take any gear at all, what can it be?
Apr 7, 2009 at 10:58 PM
REBELMHZ
Did you bleed the clutch, its a hydralic clutch and needs to be bled.
Apr 16, 2009 at 3:39 PM
