1987 Ford Bronco Bad Gas Mileage
SHORTIE1984
  • 1987 FORD BRONCO
Engine Performance problem
1987 Ford Bronco 4 cyl Four Wheel Drive Automatic
My Ford Bronco 2 was getting 20 to 22 miles per gallon, now it's getting 15 to 17! What could be doing this? My boyfriend and I done everything we could think of. Please help, thank you in advance. -Christina
Friday, June 27th, 2008 AT 1:05 PM
BLACKOP555
  • 10,371 POSTS
Whens the last time you used a fuel system cleaner?
Changed spark plugs or wires?
Sucha drop I woudl suspect a fautly o2 sensor, they cant be cleaned if they are bad.
Change air filter, check the tire pressure.
Friday, June 27th, 2008 AT 2:16 PM
