1986 Ford Bronco Wont start
130,000 MILES • V8 • 4WD • AUTOMATIC
MONTANACHAD
I have a 1986 Ford Bronco with a 302. I have replaced the Cap and Rotor, The Selonoid, Fuel pump and the Coil. And I still can not get it to run. It turns over fine but wont start what else can I do?
Aug 29, 2008 at 3:50 AM
BLACKOP555
  • 10,386 POSTS
get a spark teser and check for spark on each cylinder.
its to early to condemn the ignition system but im leaning towards it. get the results back to me first.
you getting good fuel pressure?
Aug 29, 2008 at 6:51 AM
MONTANACHAD
Thanks for your insight on this matter, I will try the spark plug tester. And I get good fuel pressure out of the fuel pump but I was told at one time I may have two a High and a Low. One may be in the tank.?. If this is an ignition problem then is there any troubleshooting I can do? You guys rock!
Aug 29, 2008 at 7:11 AM
BLACKOP555
  • 10,386 POSTS
if you have two thers a low pressure in the tank, and the high pressure is under on the frame before the fuel filter.
the troubleshooting im giving you will decide what is wrong, quite simple to do but we have to wait on the results first.
Aug 29, 2008 at 2:18 PM
